Contact lost
1384 22 2016-12-1
Ercoupedriver
Flight distance : 1075778 ft
Was just flying my P4 when I lost all contact with it.  Tried RTH, nothing.  I did the land where it was and must have got that signal.  I was flying over a small field and went there and found it.  As I drove up to the field I started getting a video signal and later found it just off the field upside down.  Is there anyway that I can see the flight log?  I know I've got to send it back to DJI but would like to see what happened.
2016-12-1
Aardvark
Flight distance : 384432 ft
Follow the instructions here to upload file to Phantomhelp, some of the experienced pilots here might be able to suggest what happened.
http://www.phantomhelp.com/LogViewer/Upload/
You can also view a flight record of the route in DJO Go.
2016-12-1
hallmark007
Flight distance : 12400594 ft
Hungary
You should be able to see it in editor if you were recording, you also can play back your flight through your logs, not to sure if you will get the bit were you lost the signal, also remember to sync your flight.
2016-12-1
DJI-Jamie
DJI Team
Flight distance : 112405 ft
Were you using the Go app? You should be able to play back the flight to see if there were any error messages that may have been missed. Have you already gotten started with a RMA?
2016-12-1
Punchbuggy
Flight distance : 573054 ft
hallmark007 Posted at 2016-12-2 10:39
You should be able to see it in editor if you were recording, you also can play back your flight thr ...
And I'd be changing the default 'signal lost' action to RTH, rather than have it as Land. Safer that way...
2016-12-1
hallmark007
Hungary
Punchbuggy Posted at 2016-12-2 00:42
And I'd be changing the default 'signal lost' action to RTH, rather than have it as Land. Safer th ...
He tried RTH didn't work..
2016-12-1
Punchbuggy
hallmark007 Posted at 2016-12-2 11:05
He said he lost contact and then tried RTH, but it landed where it was. Pressing RTH when signal is lost would do nothing, as you know. Sounded like the default was to land on lost signal...
2016-12-1
hallmark007
Hungary
Punchbuggy Posted at 2016-12-2 01:07
He said he lost contact and then tried RTH, but it landed where it was. Pressing RTH when signal is ...
Bit confusing he said he did land where it was ?
2016-12-1
Punchbuggy
hallmark007 Posted at 2016-12-2 11:11
Agreed, but I'm thinking it did what it was set to do - to land if signal is lost. That's impied by what was said, but he may have thought he did it. Anyway, I'm sure the poster can confirm.
Regardless, it's an unwise default. What if the signal was lost over the ocean or a lake?
2016-12-1
hallmark007
Hungary
Punchbuggy Posted at 2016-12-2 01:17
Agreed, but I'm thinking it did what it was set to do - to land if signal is lost. That's impied b ...
It does look that way.
2016-12-1
hallmark007
Hungary
Agreed, but I'm thinking it did what it was set to do - to land if signal is lost. That's impied by ...
It also may have been running short of battery if this happens it will just land.
2016-12-1
Punchbuggy
hallmark007 Posted at 2016-12-2 11:44
True, but to clarify my understanding. It'll land if that's all the power it has left to do so. If you have Smart RTH enabled, once it detects low battery based on how far away it is, it'll RTH if nothing is done for 10 seconds. But if it hits a heavy wind on the way, it'll be landing short of you...
2016-12-1
Ercoupedriver
DJI-Jamie Posted at 2016-12-2 07:40
Were you using the Go app? You should be able to play back the flight to see if there were any error ...
I was using the go app.  I just looked at the flight log in the app.  At the time I lost signal it says max altitude reached.  3 seconds later GPS disconnect (inflight) (using).  at 94 seconds Command timeout.  Then 3 minutes later another warning command timeout.
2016-12-1
Ercoupedriver
Jamie, I have not started the RMA yet.
2016-12-1
Ercoupedriver
Oh sorry, I have got it set to return at signal loss.  Also I did the land where it was after the RTH didn't work.
2016-12-1
Labroides
Flight distance : 26781877 ft
Ercoupedriver Posted at 2016-12-2 12:04
Oh sorry, I have got it set to return at signal loss.  Also I did the land where it was after the  ...
Have you used RTH before?
If you aren't familiar with the way the button works you might think it was activated when it wasn't.
If you follow the instructions given in post #2 above you can see exactly what happened instead of guessing and probably being wrong.
You can also post a link if you need help with it.
2016-12-1
DJI-Jamie
DJI Team
Ercoupedriver Posted at 2016-12-2 08:59
I was using the go app.  I just looked at the flight log in the app.  At the time I lost signal it ...
How far out were you when it disconnected? Are there any nearby towers around the field you were flying? To get started with a RMA, you can email the North American Support team either via support.us@dji.com or call +1 (818) 235 0789.
2016-12-1
Ercoupedriver
DJI-Jamie Posted at 2016-12-2 09:27
How far out were you when it disconnected? Are there any nearby towers around the field you were f ...
I was out about 2500 feet.  I have flown this same area a number of times.  There are no towers within miles of the place.  Very rural area.
2016-12-1
Ercoupedriver
Ercoupedriver Posted at 2016-12-2 09:00
What does the command time out mean?
2016-12-1
DJI-Jamie
DJI Team
Ercoupedriver Posted at 2016-12-2 11:12
That normal means that the unit was trying to perform an action, but it could not complete it.
2016-12-1
Ricardo
Puerto Rico
2016-12-1
Ercoupedriver
Ercoupedriver Posted at 2016-12-2 11:11
I was out about 2500 feet.  I have flown this same area a number of times.  There are no towers wi ...
That was 25000 feet, sorry.
2016-12-2
Ercoupedriver
Ercoupedriver Posted at 2016-12-2 19:31
never mind.
2016-12-2
