lethbrp
Don't forget, when you setup your authorised numbers, be sure to add the +44 country code, else you don't get any response from the text commands. Took me a while to figure that one out.
As for the lights and button (which don't have any description in the manual), as far as I can tell, it flashes a little blue light when it has a GPS fix and the organge flashing light when its got a cell signal. If you push the button, it will call your mobile. You also have a listen in facility. Lastly the command 123456G gets the device to text you all the setting on the tracker. This includes the battery percentage charge state, which is quite handy.
My testing over the weekend, proved the unit to be quite accurate indeed, certainly to within a few meters.
