Aardvark
Flight distance : 384432 ft
Gimbal tilt setting dictates how quickly the gimbal will respond when you tilt gimbal using gimbal wheel on controller.
The gimbal pan synchronous follow rotates the gimbal slightly left or right as you yaw the aircraft left or right. It does this to try and smooth out the initial part of the yaw. Switch it on or off and watch what happens to gimbal when aircraft powered up (no props and motors not armed) and you move the yaw stick left and right. |
