Mike-the-cat
Flight distance : 22488593 ft
Battery discharge characteristics 101
Your calculations are well intentioned but likely incorrect. Flight time down to 20% of 13 min+ has been my experience too.
However, battery discharge curves are NON-LINEAR so the extrapolation down to 0% is likely incorrect.
As the constituent cells hit the lower end of their working voltage, they deliver less current. This is why the % indicator falls more quickly as you get to 25% reserve.
LiPo s should be deeply discharged occasionally but to go down to 0% or even 10% on a regular basis will shorten the life of your battery. |
