BogdanPhoto
Flight distance : 4126444 ft
Has anyone had any luck with that?
It says that "trace is supposed to work behind or in front of the subject. I have tried this with a car with both Mavic and P4 Pro - they seem to do the same thing. Car was stopped when I activated Active Track, drone was aligned with the path of the car facing the car head on... then the car starts moving forward and the drone starts moving in reverse... Car accelerated to 10-15mph going completely straight and then the drone decides to fly to the side going 20-25 mph and eventually loses the car because it flies away too far to the side and the subject is too small. No sticks were touched in the process. I understand that trace from the front is not the easiest task because the drone has to "predict" where the car will go... So I understand going to the side and tracking it from there... but just flying away to the side far enough to lose the really slowly moving car that goes straight is not something that I expected.
