DJI-Jamie
Flight distance : 112405 ft
Trekz Posted at 2016-12-12 08:12
It was definately LOS.. it was about less than 100 feet away, and it didn't respond to the c2 button until after it was inside and not flying.
Also, my playback button doesn't seem to work. When I click it the sound beeps, but nothing happens in DJi go. Can this be fixed in an update? I'm not too far away from Carson, so if it's easier for you guys, then I can just drive down there for a repair if needed.
Unfortunately, the North American Repair facility does not accept walk ins, if a repair is needed, it would have to be sent in. Just to make sure everything is communicating properly, please try the following button combinations:
Reset the RC:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
Manually relink the RC:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button on the controller, then the controller will beep like D-DD.
*Let go all fingers, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
