Geebax
You cannot charge anything through the USB connection on the aircraft. Your friends explanation of the different voltage between a car USB port and a wall outlet is also wrong, all USB ports supply 5 volts, it is a standard. But the battery in your aircraft is 15.2 volts, so you need a proper charger for use in the car. There are a myriad of ones on eBay for about 20 bucks that will do the job just fine. DJI make a decidicated car charger, but it is expensive.
