P4 pro jerk frame
17223 310 2016-12-14
fans_drone
Geebax Posted at 2017-2-4 13:35
Is there something you wish to say???
I think that this mac don't has problems to edit and read 4k 60fps
2017-2-5
Geebax
fans_drone Posted at 2017-2-5 13:50
I don't use Macs, so I can't say.
2017-2-5
fans_drone
HellStream Posted at 2017-1-27 16:46
I posted 6days ago a link with my video clip and no answer so please DJI, can you kindly answer. Do I need to send my unit back or not?
I'm using latest firmware. Tried two different memory cards and the problem is the same.
Do you have news of this problem?
2017-2-7
TheSquidd
Flight distance : 184642 ft
Reporting in, my P4P is doing the same. In my clips it is a single frame from earlier in the video (roughly 7 frames earlier). Definitely has nothing to do with the gimbal. Ruins the clip essentially as you lose the frame that it replaces. Would love to hear an answer on this or if DJI will repair my drone when/if they figure out the problem, seems to be an issue affecting a large number of P4P's.
2017-2-7
Geebax
TheSquidd Posted at 2017-2-7 16:21
If you want an answer to something, then ytou need to reply to a post by one of the DJI representatives, otherwise it does not come to their attention.
2017-2-7
fans40289743
Flight distance : 728478 ft
DJI Natalia Posted at 2016-12-17 23:19
I downloaded the file you uploaded, unfortunately, I could not open it.
Would you please try again to upload to a dropbox without edition? thanks.
I had no problem viewing the video.
2017-2-7
HellStream
Flight distance : 1370771 ft
Finland
fans_drone Posted at 2017-2-7 14:10
I returned my drone to the dealer, since i didn´t get any answer from DJI. I immediately received a third P4Pro.
This is an UPDATE for my third one:
My first short test flight with my 3rd one was inside my studio. I tested 4K 60FPS and very first clip was ruined, because the gimbal made a sudden very fast movement. This happened when i was panning from left to right.
After that when the weather was a little bit better, i went outside a did 3 test flight. All the clips were good from the first flight.
I had to do the IMU calibration after this flight. It told me to do.
Then i made the two other test flights with no problems.
I will keep testing.
However, the biggest problem is now that the drone doesn´t fly straight at all.
2017-2-8
JAEHYUK CHOI
South Korea
Dudes, I also have popping frame with P4Pro since my 1st recording (last Sunday) and here are a lot more P4Pro with same problem in Korea.
DJI said it will be fixed at Jan. firmware but it didn't work at all.
So currently I and my same-problem-owners are waiting next firmware and if it fails we may refund.
2017-2-8
Farmer_mapo
Flight distance : 878373 ft
South Korea
i got a same problem
first gimbal had a same problem
and second gimbal same again.
firmware version is latest
flying more , the jerk frame more more pop up.
here is video link
and i sending  orignal clip, to dji support mail
2017-2-8
Farmer_mapo
South Korea
Farmer_mapo Posted at 2017-2-8 15:45
and aslo gimbal TWITCH still happen
2017-2-8
PinkGold
South Korea
DJI Natalia Posted at 2017-1-20 00:08
Thank you so much for your update, glad to hear everything goes well, enjoy it and let us know if you have any other questions, thanks for your supporting again!
Natalia, any update for fixing this problem?
I and some of my club members are having same problem and worries are getting bigger.
2017-2-8
DJI Natalia
Flight distance : 318 ft
epicjib Posted at 2017-1-20 17:11
I have the same issues. Multiple frame rates and resolutions. Sometimes it is dropping a frame and it glitches when it tries to recover. I tested multiple cards, same intermittent issues. Sent mine in for warranty after 6 flights. NOT confident that DJI has a fix and will play the shipping game back and fourth until they come up with a firmware fix..... https://vimeo.com/197648449/3f480dc4ef
May I have your case number since you sent it in? thanks.
2017-2-12
DJI Natalia
PinkGold Posted at 2017-2-8 16:01
I've informed our engineers again and will get back to you for any progress.
2017-2-12
PinkGold
South Korea
DJI Natalia Posted at 2017-2-12 00:12
Thanks Natalia.
2017-2-12
DJI相机部大帅哥
DJI R&D Squad
Please send us the original video in the SD card, thank you!
2017-2-14
gregcrammond72
Flight distance : 68737 ft
Hi
I have actually just bought a P4P from the DJI store in Hong Kong last week , went all the way there to get one in the hope i would get a good one ! Guess what ?? Gimbal twitch !
I spent over $3000 in the Causeway bay store only to be let down by this now
2017-2-14
gregcrammond72
Please can you help me Natalia ? I went all the way to HK last week from London to get my drone from your store and every time i fly it i get twitching .
the shop asistants in the store registered and updated my drone for me .
2017-2-14
Airwolf13
Flight distance : 36995 ft
I am also getting the jeering video. New condition. What up DJI what is the solution?  And please don't ask me to post the video, it is EXACTLY what has ben posted here.!  And I ran a few tests.  Seems to only be when I'm recording in 4K at 60 FPS.  Go figure.  Wheres the DJI fix for this???????
2017-2-14
Viridis
Flight distance : 2383556 ft
I too get a frame bump in 4k60, hoping updates can sort this.
2017-2-15
Airwolf13
Why does it take more then four days four your "engineers" to response to an issue that everyone who has a P4P have??  Cmon!
2017-2-16
DJI Natalia
Airwolf13 Posted at 2017-2-16 04:43
Our engineers replied here at #95, they need the original videos to locate the issue.
2017-2-19
Airwolf13
#93 and #94 indicate..."our engineers will back to you with any progress ..." THAT WAS ON 2.12.17.  So???  What did the 'engineers' find out??? We ALL need this issue of the 'glitching/freezing of video at 4K 60FPS resolved asap!!
2017-2-19
GreyWhite
Flight distance : 18605000 ft
OK, let me post the original video link below.
https://drive.google.com/open?id=0B7h9eU8j5TIrTDNBNlM5cXFMWlE
Jerk at 00:55
I say my problem again:
I have the same issue in 4K/60 and no problem in 4K/30, 2.7K/60 and 2.7K/30. Firmware is up to date.
Now I only shoot 4K/30, 4K/60 is absolutely crap!!
2017-2-20
GreyWhite
Still no updates?
2017-2-23
Airwolf13
DJI Natalia Posted at 2017-2-19 00:26
Hey Natalia, its been a while...so HOWS THAT FIX COMING ON THE CHOPPY VIDEO?  Engineers still at it??
2017-2-25
idrone4u
Flight distance : 182730 ft
I have the same issue.  I have two phantom 4 pros at the moment and both of them show this issue.  I will be returning both.
2017-2-25
DJI Natalia
GreyWhite Posted at 2017-2-20 01:12
Please click on "Reply" button so that I can get a remind.
I've transferred the original video to engineers again, thanks for your supporting!
2017-2-25
gregcrammond72
Totally agree , only happens at 4k 60fps , its useless at 60fps
2017-2-27
kykphantom
Flight distance : 5892388 ft
Cyprus
DJI Natalia Posted at 2017-2-25 20:46
I confirm that my Phantom 4 Pro has the same issue.
2017-2-27
DJI相机部大帅哥
DJI R&D Squad
We have solved this problem. But we need to do more tests before releasing firmware  with this patch. Sorry for waiting this. And thank you for your feedback.
2017-2-27
CrookedHorizon=
Tip: The post by the administrator or moderators shield
2017-2-27
CrookedHorizon=
Have you solved the problem of the crooked horizons and the constant wind warnings as well?
2017-2-27
kykphantom
Cyprus
Footlink Posted at 2017-1-19 07:50
I have found this same jerking issue on two occasion shooting 4K at 60 FPS.  Both time when the aircraft is rotating.  Once to the left and once to the right.  Using a Sandisk Extreme sd card didn't solve the issue.  Changing the gimbal setting didn't solve the problem either.  I'm using a brand new 2016 15" MacBook Pro with I7, 16 gb of ram and a blazing fast 1TB internal SSD so processing power or slow disk shouldn't be the issue.  I then looked at every single frame and found that one frame actually went backward causing the jerk.  Cut out the frame and the video looks normal.  By the way I have the Plus with the built in screen and on the video stored in the controller it also had the jerk.  Can't say if it's the gimbal or the compression algorithm but haven't seen this jerk flying in a straight line.  Hope DJI and give us an answer soon.
Yes, I have the same problem with my P4P, and I checked the video frame by frame. I found that one frame actually went backward causing the jerk, at 4K 60fps. I don't think that the camera can move so fast (1/60s) and produce this erroneous frame, but on the other hand, DJI must reply with a clear position on this issue.
2017-2-28
kykphantom
Cyprus
2017-2-28
fans34e58059
Something similar is happening to my P4 Pro quite a few times. However, the times I noticed it, it was associated with changing directions (like pushing the stick to the left while the bird was going right, etc.) Also, I tried to replicate  it when having the bird very low and close to me, so I can in a way 'visually inspect' what's going on. It looks to me that it's not the gimbal's fault; the whole bird is jerking when changing direction, and I'm guessing the gimbal just cannot follow this sudden vibration. Note that it happens in 4K/24p. I haven't tried 60p yet. It looks like that:
Obviously, this has nothing to do with either SD card (I have a  SanDisk Extreme Pro, perfectly able to handle 4K in high bitrates), neither with a dropped frame, as there is actual physical vibration.
Is that something common or should I return?
2017-2-28
Geebax
fans34e58059 Posted at 2017-2-28 14:07
https://youtu.be/XnYvXO2Nwr0
I can get something as minor as that movement on my P3P when I suddenly change direction, nothing unusual about that. But it is easily fixed, don't make sudden direction changes.
2017-2-28
betonven
Geebax Posted at 2017-2-28 14:33
Thanks for sharing. What bothers me is that it happens randomly. After this video, I tried to do it several times and it perfectly smoothly transitioned from left to right and back.
When it happens, I can hear the engine roaring aggressively (I'm guessing trying to fight inertia) and probably this gives the vibration. I just wonder why it happens only randomly.
P4P problems are a horror story, and I just want to make sure nothing's wrong before Amazon's 30 days return deadline expires. I don't want to have to deal with DJI  for service again, I returned a DoA Mavic Pro two full weeks now and it still doesn't even show up as a progress indicator in my account, to keep track when I'll finally get a refund.
Great company, fantastic products, but it looks like there is a serious problem with both quality control and customer support.
2017-2-28
Geebax
betonven Posted at 2017-2-28 16:32
I understand your concerns. But I would not count it as a defect. As I said, my P3P does something similar so I just don't make agressive moves when shooting. In fact I nearly always program my flights now to make them smoother.
2017-2-28
kykphantom
Cyprus
Dear Natalia, could you please check my videos too? I submit two videos recorded at 4K/60fps where you can see clearly the jerk issue. Both videos are taken directly from the SD card without any editing.
Jerk at 0:28s
Jerk at 0:30s
2017-3-1
gregcrammond72
2017-3-2
