TheMann58
Flight distance : 18669501 ft
GadgetGuy Posted at 2017-6-19 06:12
Since you purchased a brand new aircraft and immediately installed a new firmware version, without first flying the aircraft on a prior version and experiencing video glitches, how can you thereby conclude that the firmware update fixed the video glitches, if they were never present in the first place? How can you know that it wasn't new and improved hardware, or simply a good version of the aircraft that would have been video glitch free on prior firmware? Have you downgraded the firmware and experienced video glitches? Replacing hardware and upgrading firmware at the same time proves nothing about the firmware update having fixed a problem the aircraft never was known to have had in the first place.
I received my repaired P4P back from DJI 10 days ago, after they replaced the camera and gimbal because a gimble twitch spontaneously started after 30 problem free flights. Before sending it in, I experienced an average of three video glitches per 23 minutes of video on the 1.02 version on 30 flights, which I found tolerable. This was the only aircraft of ten differnt P4P aircraft that I tested since December which had so few video glitches, so I wanted nothing unnecessary changed on it. I told them NOT to upgrade the firmware. They upgraded the firmware anyway to the 1.03.0509 version.
GadgetGuy,
Sorry you are having so much troubles with "video glitches" when viewing 4K/60 fps and 4K/30 fps video recorded on your P4P aircraft.
To answer your question, I owned an earlier P4Pro aircraft running the .0402 firmware (the latest at the time), which exhibited a number of issues including the random video frame insertion glitch and unlevel gimbal horizon especially when flying in wind even after IMU and gimbal calibrations. I was hopeful these issues would all be corrected, in time, with firmware updates, but I didn't want to wait, so I returned that P4Pro to Best Buy for a refund.
When the 0509 firmware was released and DJI reps confirmed that it addressed the video insertion glitch issue in 4K/60 fps, I bought a new P4Pro from Best Buy, installed the latest firmware, performed an IMU and gimbal calibration and confirmed that, on my new P4Pro, the video frame insertion issue (aka, "jerk frame", aka "video glitch) had been addressed completely by the 0509 firmware. I can now further confirm that, for me, the 0510 firmware has completely address the tilted horizon (aka "gimbal tilt") issue in all recording modes.
Many other users and DJI staff posting to this forum have confirmed that the 0509 firmware also corrected their "video frame insertion" (aka, "jerk video") issue in 4K/60 video recorded on their P4Pros
A few comments:
The vast majority of users complaining about "video jerk" or "random frame insertion" video glitches on this forum (myself included) only noted 2 to 4 such instances in a 15-20 minute video recording session with their P4Pro aircraft and camera using the 0402 firmware and this issue was resolved after installing the 0509 firmware.
Since you are seeing many more video glitches (17-20 per flight) per flight BOTH with older firmware (0402 or earlier) AND after installing 0509 firmware and you indicate this is the case with multiple aircraft you have tested, I think you may want to investigate OTHER possible causes for the video glitches you are experiencing. I do not wish to upset you or indicate in any way that you are not a knowledgeable videographer or drone pilot. You obviously are experienced in both based on your avatar Flight Distance of almost 6 million feet. I only offer the following as suggestions, which you may have already investigated yourself:
1) Is it possible the combination of computer hardware and/or video viewing player software and/or editing software you are using is generating the video glitches:
- have you tried using another high-end computer/laptop to view the video files to see if the location, or frequency of glitches changes (if so, then the video file is not the problem)
- do the video glitches appear on exactly the same frames EVERY time you view the same video file? (if NO, then the video file is not the problem)?
2) Is it possible you are using micro SD cards that are either not rated to handle the 4K/60 100 megabit/s video output from the P4Pro camera?
- Do you have these video glitches using the DJI-supplied micro SD card?
- Have you tried using other high-end U3 V30 rated 90+ MB/s write-speed-capable micro SD video cards and you still get multiple video glitches per video?
- Note: Even though the P4Pro is compatible with them, I do not recommend using 128 mb capacity micro SD cards as many card readers and some computer systems/operating systems do not handle cards greater than 64 GB in capacity well and can produce file errors and file corruption
- I can personally recommend SanDisk Extreme Plus 64 GB V30 micro SD cards; they work flawlessly for me.
- I watch all my videos glitch-free at full 4K/60 and 4K/30 using the following:
a) Intel i7 920 processor (certainly not the latest and greatest, but good enough) with 24 GB RAM running Windows 10 watching videos with Windows Media Player
Again, sorry for your issues with multiple P4Pros. Video recording file glitch issues have been resolved for me (and many others) with the 0509 firmware. And the 0510 firmware released on June 9th has now also FINALLY resolved the tilted gimbal issue, especially when flying in wind. |
