Aardvark
Flight distance : 384432 ft
If there is not enough light in your office for the Visual Positioning System to work then it will show 'Ready to go (no GPS)', and it will swithc to 'ATTI' mode, i.e. no positioning. In this mode it will be prone to drifting about.
If enough light then VPS will work, and the bottom camera sensors will help hold the aircraft steady.
It is probably not a good idea to fly indoors until you gain a good bit more experience about controlling the aircraft and learn how it will react in different situations. Worth reading through the manual a couple of times, particularly the section on 'RTH'.
