JasonMBryant
Copying videos to the camera roll is the worst part of the Osmo Mobile. However, it can be done. Someone else posted the instructions, but I couldn't find them, so I'll just repeat them.
1) Open DJI Go.
2) Connect to the Device. Hit this button even if your Osmo Mobile isn't turned on. If it isn't turned on, then hit the blue "Camera" word that appears on the left. You can access the program even when the Osmo Mobile is turned off.
3) Hit the little "play" button in the bottom corner. That looks like a triangle in a square.
4) Press "Select" in the top right corner.
5) Tap on each of the videos you want to copy. They'll have a check mark on them when selected.
6) When you've finished selecting all your videos, press the "Save" button at the bottom.
7) This is also where you'll delete all these videos, when you're ready. You'll have to do that occasionally because they take up space in both the camera roll and the DJI Go app.
There you go. |
