HELP!!!!!!!!!!!!
1066 12 2016-12-18
olympic_spice
Flight distance : 98934 ft
So i got my Phantom 4 a couple months ago and i am loving it. No proplems whatsoever. But then something very annoying started happening to it. Last month the Phantom decided to stop reading the SD card and displaying messages "No SD Card." But there is one in. I have restarted the drone, remote, and my phone many many many times and nothing is working. I cannot record or take photos, i dont know what it is:/
Anybody else have this proplem?? Any thoughts?
I am using a Sandisk ultra 32gb card. This isnt a cheap SD card.
THANKS!
2016-12-18
trance728-
Flight distance : 298048 ft
Have you tried another card?
2016-12-18
olympic_spice
trance728- Posted at 2016-12-18 13:43
Yes, that didn't work.
2016-12-18
Aardvark
Flight distance : 384432 ft
The card is the correct way round, contacts facing up the way ?
2016-12-18
trance728-
Aardvark Posted at 2016-12-18 14:22
You can't insert cards upside down, that's why they're shaped the way they are.
2016-12-18
Aardvark
trance728- Posted at 2016-12-18 20:32
Well you never know, some have tried I'm sure
Especially as the P3 series are contacts down.
2016-12-18
Geebax
The Sandisk Ultra card is a borderline card, it is only barely able to record fast enough, because it is not specified for a fast enough sustained recording rate. Try a Sandisk Extreme Pro or Sandisk Extreme.
Also, it may stop working if you keep simply copying off the files or cutting and pasting, so each time you copy your files off, put it back in the aircraft and re-format it.
2016-12-18
fansa84fe8a4
Flight distance : 3 ft
trance728- Posted at 2016-12-18 12:32
I managed to do that on a new cellphone.  It can be done, and I got a bill for $150 to fix it along with a note of "Customer abuse and warranty voided" but I knew I did it too.
Too bad DJI doesn't put a little symbol on the slot with some gold markings for the pins pointing up or something as it does seem backwards as it is.
2016-12-18
olympic_spice
yes double checked that
2016-12-18
DJI-Jamie
DJI Team
Flight distance : 112405 ft
Just to clarify, did you notice this after a firmware update or did it just happen randomly?
2016-12-18
olympic_spice
DJI-Jamie Posted at 2016-12-19 00:16
it happened after the firmware update
2016-12-27
DJI-Jamie
DJI Team
olympic_spice Posted at 2016-12-28 04:06
Most likely, the unit's SD card port has become corrupted. Have you already gotten in contact with the North American Support team in order to look into a repair service?
2016-12-27
Aardvark
olympic_spice Posted at 2016-12-27 20:06
Have you tried a firmware refresh, followed by a factory rest in DJI Assistant 2 ?
2016-12-27
