Best Photo Editing Software
12
15930 61 2016-12-19
JoiCam
Flight distance : 771434 ft
Iceland
So finally now I have quit using Lightroom after a lot of testing on Capture one 11 from Phase one  which I like much more and bought it.
And also as said before I am using Affinity Pro in instead of Photoshop and do not regret that switching ether.
2018-1-7
Rodger8
Flight distance : 20145135 ft
Rigger73 Posted at 2018-1-7 04:18
same.  No brainer for me - and had asked on the Affinity forum alongside a host of other users.
That's the other plus point for Affinty Photo - the devs take part in the forums, and not only offer advice to users, but will also answer questions and take onboard what users are saying.
Thanks for the heads up, I'll check out the forum. I would rather pay as I go than a monthly commitment. I am still searching for a good mapping program with pay as you go rather than a monthly commitment.
2018-1-7
stalker
Flight distance : 13632 ft
DXO photolab. P4P has finally been added to the database. Best choice.
2018-1-7
SKY-CINEMA
Flight distance : 754767 ft
Moldova
Lightroom is great to edit RAW images. Than I use Photoshop to reduce noise, add sharpness and so on. You may use RAW editor in Photoshop but it has small number of features. Lightroom is better.
2018-1-7
SKY-CINEMA
Moldova
2018-1-7
Steven Black
India
Hello,
I would recommend you to use photoviewerpro (https://www.photoviewerpro.com/). It is highly effective and user friendly. You have to just do onetime payment and you can avail the application update benefits freely. You can try 21 days trial period.
It has lots of feature, but I can specify the best one here:
1. Dual monitor configuration support
2. More than 150 transition effect
3. Compare images side by side (up to 4 at a time)
Regards,
Steven
2018-3-23
Aerial-Image
Flight distance : 1452408 ft
Lightroom-Photoshop package plus Premier Pro for Video's Send my images out to be calibrated printed at a pro print shop - easier and cheaper in the long run.
2018-3-24
LaslieHarley
If you’re looking for a relatively easy to use and powerful free photo editor , that isn't GIMP, you may try Digital Photo Professional from Canon or LightZone. Rawtherapee is probably one of the better free raw image editors, Darktable is also worth a look if you use Linux or OSX. Neither are as good as Lightroom for library management and high volume work but can be better for making detailed adjustments to a small number of images. Lightroom costs $119. Compared to the expense of everything else in photography it is dirt cheap. You will use it for every photo you process, and it'll help catalog your images too
2019-1-31
KennyB
Flight distance : 674137 ft
Photoshop for sure....although for basic photo editing and organization Lightroom would also work.
2019-1-31
maryaustin
Bangladesh
My vote also goes for Adobe Photoshop. It's pretty effective in every way. But sometimes i use Lightroom for my need.
You should Check out my portfolio, what can I do with Photoshop - Jewelry image editing by Adobe Photoshop
2019-2-6
Joshua Saprano
India
Have you tried photoviewerpro? Try and see it works perfectly well.
2019-3-16
prelly
Cambodia
Personally i use the photo editing software from https://www.photo-editing-software-for-windows-10.com/ because it is easy to use and have o lot of useful functions and all what i need. Its so simple that even my daughter (9) can handle it very good and she like that there are so many photo effects.
2019-3-28
Mark Weiss
Photoshop here. I've been using it since the 1990s when I switched from Aldus Photo Styler to Photoshop.
2019-3-28
Manxmann
Flight distance : 1178793 ft
Svt04cobra Posted at 2016-12-19 17:45
I'd like to know what everyone is using also.
Me too
2019-3-29
clairewhite
Taiwan
Neither Photoshop nor Lightroom. I use https://www.widsmob.com/retoucher
Budget and friendly to newbies.
2019-6-6
RedHotPoker
Flight distance : 165105 ft
It came in my bundle... hahaha
RedHotPoker
2019-6-6
*DM*
Flight distance : 507087 ft
This is a tricky one. Most editors excel in one or two areas but lack in others. Most Pro's use multiple ones, even ones that rent the complete Adobe package.
You want the best noise reduction? The best RAW converter? The most versatile, cheapest? Do you want 'old school' editing where every parameter is done manually in steps or do you want to make use of the increasingly powerful AI in some packages giving you some help without resorting to 'auto' modes?
You are unlikely to find 'the best' in one package.
Monthly subscription, one-off or 'to upgrade only' fees?
Adobe is probably the defacto choice but the monthly subscriptions soon mount up substantially. Ok if you are a pro and make a living  out of of it but perhaps overkill for hobbyists plus once you stop paying ...
On1 Photo Raw (2019) is a one-off charge. It's yours forever but if you want to update to the latest version every yearyou have to pay again if you need additional, new features although its (slightly
2019-6-6
*DM*
... cheaper if you already have an existing version. Still cheaper than Adobe but you are lacking some features (many of which many never need).
It's a fantastic Editor with very advanced AI algorithms, making editing fun and, if you wish so, less time consuming though it has most traditional step by step modes so you can do that too. Weak points ... Noise reduction. Not the best but neither are Adobe/Lightroom or most other well known editors. (There is really only one choice for the most effective noise reduction and its relatively expensive; DxO OpticsPro 11 Elite). Other than that ONE1 should give most photographers what they need for editing. It can be a little slower, depending on hardware used but the makers have improved it considerably over the years and considering the power on hand, it's not an issue.
I could go on and on, there are so many but perhaps worth pointing out another Editor which is very powerful and with a low one-off fee of $50 with no further cost;
2019-6-6
*DM*
... Affinity.
This really is almost a complete Adobe Lightroom replacement but adding further functionality beyond LR.
Downsides ... more involved to learn but if you come from Adobe you will have little problems. Much of the interface is similar. - It can be slower than Adobe and there are some little bugs here and there but the developers are continuously improving the software.
There are many others. You have to prioritize what exactly you need and weigh up cost.
2019-6-7
Manxmann
I use Pinnacle Studio ...........  and I feel like an orphan !!  No one else seems to like it
2019-6-12
lebone
Bangladesh
Gotta say I’m a fan of Adobe Creative Suite. Even I've got both Designer and Photo from Affinity. I am practicing how to use Affinity Photo right now. Honestly, there are too many choices now (https://clippingpathindia.com/blogs/tips/what-s-the-easiest-photo-editing-software-30-tools-to-choose-from/) but It principle makes it impossible for me to try new items because of the learning curve. What is yours?
2020-10-18
Peter Kolarov
Ukraine
Pesnonally I used sometimes online photo editors edding side effects/animation ,maybe that will do to your request although Photoshop is more advanced in terms of instruments ,https://crello.com/create/animation-maker/
2021-6-30
12
