s900+a2 yaw issue
847 2 2016-12-19
pbetancourt
Flight distance : 2106670 ft
Argentina
Hi friends,
I had a crash with my s900+a2+LB2.
I recalibrate the imu and GPS. All performed well.
The drone is flying OK towards, backwards and left to right. But when I turn (yaw) to the left, after leaving the stick, the drone returns a some degrees to the right. If I turn to the right, when leaving the stick, the drone continues turning clockwise.
Not sure what to do.
Many thanks,
Pablo
2016-12-19
DJI-Jamie
Flight distance : 112405 ft
Do you happen to have a short video of how it behaves? Have you already checked your frame and motors to ensured that everything is still aligned properly?
2016-12-21
Skyris
Flight distance : 333799 ft
I have had the exact same issue today, I havent taken it ou tin a while but the last time I used it it was ok, did you manage to fix this?
2017-12-6
