fansa84fe8a4
Mine often shows -50 feet on landing (Take-off zero), but yours at -200 feet is really odd.
When you play it back in Fight Review in GO, how does the displayed altitude behave? Mine will seems okay, then it drops to maybe 6 feet, then a while later jumps way back up, then down, and near the end of the flight it is really down. This is mostly flat field flying over a distance of 3,000 feet too. I would think the thing with all its underbelly sensors would report zero upon landing, but it doesn't in my GO playbacks.
It might be the barometer is getting some turbulence within the aircraft's covers. Maybe the bottom VPS sensing system is getting into the mix too, albeit wrongly. It does seem different on still air days too verses windy days where it's worse. Might be a combination of the barometer not being in static air inside the frame as well as the GO program or the firmware being off or sampling wrong. The iPad Air 2 + Cellular I have barometer built into it is much more stable in readings than the one in the drone, ime. Something is screwy in the drone someplace and one GO update was reported as addressing some of that too.
Fwiw, I was reading about Trimbal's surveying drone which claims an accuracy to within 7 inches. No where have I seen that sort of accuracy with the P4 I have, it's more like 7 meters.
Good luck sorting it out.
