JoostBoZ
Flight distance : 545948 ft
Singapore
DJI-Ken Posted at 2017-1-8 20:33
Can you upload your DAT and vision files of the last flight to Dropbox and post the link here.
Also, if you start a ticket or case, please provide the number.
Alright, by the looks of it, we have many Mavic owners with the same problem. Hence, maybe the following is a good summary of the problem, observed behaviour, possible cause and an interim / temp solution.
___________________________________
Mavic Pro Automatically Ascends Without User Input
Problem description: In mid-flight (at any random current altitude) the Mavic automatically and continuously ascends without any user input (i.e. stick input, app input, etc.). A typical response of users is to stop the continuous ascend by holding the left remote controller stick down which forces the Mavic after 3 seconds into a 'Forced Landing' mode.
Observed anomaly: Remote controller and DJI GO app indicate suddenly a change of the ground clearance to a value 'very close to the ground'-value (e.g. 0.1 meters/ft) while the Mavic is still in mid-air. In reality, the ground clearance did not change and remained stable.
Possible cause: Mavic ultrasonic sensor data is misinterpreted by firmware / software resulting in a sudden change of ground clearance value. This sudden 'very close to the ground'-value triggers the Downward VPS mechanism of the Mavic to ascend to avoid collision with the 'ground'.
Interim / temp solution: Turn off a part of the VPS mechanism, which can be done by:--> For iOS users: disable the Downward Facing VPS (found under Visual Navigation Setting --> Advanced Settings --> Downward Facing VPS / Enable Vision Position' --> turn setting to 'off' / 0)
--> For Android users: disable the "Landing Protection" option (found under 'Advanced Vision Settings' -> just below 'Enable Downward Positioning System" and above "Precision Landing". Note: such setting is not present in iOS and only the entire Downward Facing VPS can be turned off.
@DJI-Ken: I'm a bit hesitant to open a ticket and potentially trigger a RMA for my Mavic as I strongly believe this is a firmware issue (due to the high number of problems reported here after the latest firmware update). For me, this is my first drone and after disabling the Downward Facing VPS the Mavic doesn't show this problem anymore. After waiting for 6 to 7 weeks of delivery time of the Mavic, it's now for me time to try out the Mavic (even when this means disabling part of the VPS). I trust DJI will update the firmware to fix this bug very soon. If this wouldn't be the case, I might trigger the RMA at a later stage.
