Jit
Flight distance : 536768 ft
Singapore
I've just done another flight this morning and it happened again. The VPS clearance indicator would intermittently change to 0.1m while my drone was up in the air, and due to the obstacle avoidance, it would start gaining altitude on its own to try to escape the virtual obstacle. Pulling down on the altitude stick would trigger the auto-landing sequence.
I then tried running some tests - I hovered at about 15m and waited for the VPS indicator to show 0.1m, and when it did happen, i triggered the auto-landing sequence, and it slowly descended till it reached the ground and rotors shut off. So those who are afraid that your drone might shut off in mid air, it most likely won't.
Turning off VPS solved the issue for me. Since it wasn't bothering to sense what was underneath, it did not enter landing mode, neither did it shoot up uncontrollably into the sky. However, you do lose ActiveTrack features, as well as the auto-land so you will be in full manual control of landing the drone, which can be a little difficult especially if you have a small space to land. Without VPS, the drone's hovering is also not as precise so it may dance around a little due to the upwash as it gets closer to the ground. What I did was turn off VPS, get relatively close to my intended landing zone, turned on VPS, and quickily initiated the auto land sequence before my drone started climbing too high.
DJI - PLEASE TELL US THIS IS A FIRMWARE ISSUE. I would hate to send my drone at this point.. |
