Phantom 4 Pro Consistantly Losing GPS Signal mid flight
123Next >
25209 116 2016-12-24
tydoblanko-sp
Flight distance : 1036253 ft
Hi all,
Whenever I fly my P4P, it always loses gps signal mid flight. Before taking off it always gets 15+ satellites and has full gps signal strength bars. However, about 5-10 min into flight the gps signal strength will drop off to about 1 to 2 bars and the craft will switch to atti mode. For the rest of the flight it will switch back and forth every minute or 2. I thought it may be intereference in the area so I tried in different locations far apart and still similar issues. Any ideas here?
Thanks
2016-12-24
HellStream
Flight distance : 1370771 ft
Finland
Have you updated to the latest firmware and made the IMU & compass calibration?
2016-12-24
f3honda4me
HellStream Posted at 2016-12-24 12:15
What does IMU and compass have to do with losing gps signal?
2016-12-24
HellStream
Finland
f3honda4me Posted at 2016-12-24 20:56
My P3Pro did similar thing all the time. I did the IMU and compass calibration and problem was solved.
2016-12-24
tydoblanko-sp
Tried all that. Was a bit better but still got weak gps signal and switched to atti. (maintained 20 satellites the whole time)
2016-12-24
tydoblanko-sp
Within seconds this happened
2016-12-24
Geebax
What sort of area are you flying in? Are you in open country, or urban canyons with high buildings? I notice the GPS shows a good number of satellites connected, so the weak GPS signal is puzzling. IMU and compass calibration have nothing to do with the availability or strength of GPS signals.
2016-12-24
tydoblanko-sp
Geebax Posted at 2016-12-24 13:31
Completely flat as far as the eye can see over a field. Just a small suburb nearby. I tried in this location and also about 10 km away. Also note I have flown in this area with a phantom 4 with no issues.
2016-12-24
Geebax
tydoblanko-sp Posted at 2016-12-25 07:44
Then I would be making arrangements to exchange it or have it fixed by DJI, that sounds like a fault to me.
2016-12-24
f3honda4me
Yep sounds like a hardware issue. I'd contact DJI
2016-12-24
HellStream
Finland
I really don´t know if this helps but which frequency are you using? 2.4 or 5.8?
2016-12-24
Labroides
Flight distance : 9991457 ft
HellStream Posted at 2016-12-25 09:20
No that has absolutely nothing to do with reception of GPS satellite signals.
2016-12-24
jetforce
Denmark
there have been some K-index interference the last 3 days.
normaly nothing to worry about, but who knows.
http://www.gfz-potsdam.de/en/sec ... kp-index/quicklook/
2016-12-24
DJI Natalia
Flight distance : 318 ft
Would you please sync your flight records through the DJI GO APP firstly?
Then please export the flight data through Assistant 2 when it happened, send an e-mail to support.us@dji.com with your APP account (e-mail address) and the exact time it happened, our engineers will help you analyze the data.
2016-12-25
Fiveform 2
Flight distance : 136230 ft
I had the same issue, flying today, but no issues in 10 previous flights in other locations.  I recalibrated IMU last night, but hadn't done a compass calibration today.  Pre-flight status was all good, per DJI Go4 app on Android.
2016-12-25
Mike-the-cat
Flight distance : 22488593 ft
New Zealand
Fiveform 2 Posted at 2016-12-26 15:02
GPS operation does not depend on the IMU.
DJI's hardware is generally top notch so if you have a problem with loss of GPS, either there is something very anomalous about the 'clear' area you are flying or there is a fault with the GPS module. Its very unusual for that to fail but if this problem recurs in different locations, that would be the issue.
2016-12-25
Fiveform 2
I took a look at my flight records and it seems like while GPS is acquiring satellites that the GPS "loss" is logged. I'm only seeing this at beginning and end of flights as VPS is engaged on landing.  I'll assume that is how it should work.  However, my overview of the flight log entries is that they can be a bit misleading and in many cases, superfluous.  For instance, there are also entries which state that I switched to ATTI mode when I definitely did not (could that indicate a loss of GPS, in other terminology?)
FOLLOW-UP 12-26-2016:  I took my P4P out for a 25 minute flight this morning in temps around 25 degrees F.  Tried out manual flight, as well as a few Intelligent flight modes and experienced zero issues.  In fact, handling, responsiveness, and expected behaviors were all perfect. Hopefully, many of the minor issues are a matter of familiarity and not hardware or software related.  Onward and upward!
2016-12-25
tydoblanko-sp
DJI Natalia Posted at 2016-12-25 02:53
Then please export the flight data through Assistant 2 when it happened, send an e-mail with your APP account (e-mail address) and the exact time it happened, our engineers will help you analyze the data.
I reported the fight record from the dji assistant. Is that good enough or should I email as well? The flight data file is large (~400MB)
2016-12-26
DJI Natalia
tydoblanko-sp Posted at 2016-12-27 03:06
There is no need all the flight data, please just export the data when the problem occurred and upload that to the dropbox.
Just to clarify, your APP e-mail address is the same for forum register, right?
2016-12-26
tydoblanko-sp
DJI Natalia Posted at 2016-12-27 00:08
Yes my email is the same.
2016-12-27
DJI Natalia
Thanks, please upload the flight data as well and keep me posted, I'll transferred the data to our engineers for analysis.
2016-12-27
tydoblanko-sp
DJI Natalia Posted at 2016-12-27 23:35
I already sent the data to us.support@dji.com is that good enough?
2016-12-29
DJI-Jamie
Flight distance : 112405 ft
tydoblanko-sp Posted at 2016-12-29 21:44
I already sent the data to  is that good enough?
That's a great first step, could you happen to provide the ticket number for further follow up?
2016-12-29
DJI Natalia
Sorry the correct e-mail address should be support.us@dji.com, please double check it and make sure it's sent out successfully.
2016-12-30
tydoblanko-sp
DJI-Jamie Posted at 2016-12-29 22:06
The ticket number is 375896. Thanks!
2016-12-30
CineView Media
Flight distance : 5365522 ft
Norway
Same happend to my brand new P4P today, gone after second flight, all went black after a short "weak gps signal" warning, then it just flew away.
2016-12-31
tydoblanko-sp
DJI Natalia Posted at 2016-12-30 00:25
Sorry the correct e-mail address should be , please double check it and make sure it's sent out successfully.
I got a ticket number that i posted above. Do you have any updates?
2017-1-1
Geebax
Fiveform 2 Posted at 2016-12-25 19:39
'For instance, there are also entries which state that I switched to ATTI mode when I definitely did not (could that indicate a loss of GPS, in other terminology?) '
It is poor wording, it is not saying you switched to ATTI mode, the aircraft is doing it automatically. This is usually in response to a compass error or perhaps a loss of GPS lock.
2017-1-1
DJI Natalia
tydoblanko-sp Posted at 2016-12-30 17:45
Our support will take care of your case and reply your e-mail once they are back to office. Sorry for any inconvenience caused, and thanks for your support again.
2017-1-1
tydoblanko-sp
DJI Natalia Posted at 2017-1-1 22:16
They emailed me saying they would send me a shipping label within 1-2 business days over a week ago and I still haven't received anything. Can you please tell me what is going on? Issue # 375896
2017-1-13
bluemarley67
Flight distance : 1242638 ft
I would be willing to wonder if there is strong magnetic forces in the ground maybe high iron? I used to have a p3s that had a bad compass module and this does seem to be quite a bit like your issue
2017-1-13
Geebax
bluemarley67 Posted at 2017-1-13 11:46
Iron ore in the ground would have no effect at altitude, and it would not affect the GPS receiver.
2017-1-13
bluemarley67
But it would to the compass
2017-1-15
DJI Natalia
tydoblanko-sp Posted at 2017-1-13 07:38
Very sorry for the inconvenience caused, we've reported this case to our support team, who will reply you soon.
2017-1-16
Gulars
Norway
Hi im having a similar issue with mu P4P+ did this get resolved for you? what was the conclusion. I am currently on chat with a guy who calim the drone wil return home if it looses GPS.
2017-2-13
fans06257e97
Flight distance : 3009616 ft
Brazil
DJI Natalia Posted at 2017-1-16 00:36
i've bought a Phantom 4 pro plus 2 months ago and since de first flight, there is the same problem. Yesterday the drone became totally crazy in the air, flying in high velocity when lost gps signal. i'm trying to contact assistance DJI in Brazil, but they tell me that they can't do nothing.
2017-2-15
fans06257e97
Brazil
2017-2-15
fans2ddaaf7b
Finland
I had this same problem also last weekend, drone (P4P)kept on switcing to atti mode all the time even tere was plenty of satellites, the drone was drifting and almost impossible to fly straight line, the the gps came back and in couple of minutes it went back to atti, this was happening many times untill I lost connection to the drone completely, "aircraft disconnected", luckily the connection.came back in about 30 seconds  and I was able to fly it back manually. the temperature was around 0 degrees celcius.
2017-2-15
Vasilis
Flight distance : 163658 ft
Greece
Happens to me constantly.  I have flown  on different areas and the problem keeps coming.  The real problem is that it cancels the RTH and you have to fly back manually.  I have upgraded to the new firmware and the problem appeared again.
2017-2-16
Geebax
Gulars Posted at 2017-2-13 06:42
'I am currently on chat with a guy who calim the drone wil return home if it looses GPS.'
He is totally wrong. If the aircraft cannot receive GPS data, it cannot RTH, as it needs the GPS data to know where home is.
2017-2-16
123Next >
