I purchased A hoodi shade for my iPad. I am currently using it on my iPad air 2 and it seems to work pretty well. They do seem to be out of stock currently on the hoodi for the iPad Air on their website. These hoods are also a bit expensive at around $37 however they are well-made light and easy to attach. Only warning is need to be careful when it is mounted to your controller as it may make it easier to fall off if you tilt your controller to an extreme angle as the mount goes over the hoodi. I guess you could try to cut the hoodi so the mount would be directly on the iPad but I don't think that is nessary if you are careful.
