Gary Mac
Flight distance : 741683 ft
There is a little drift when you don't have GPS. You WILL have to "fly" it a bit when you are in ATTI mode (no GPS). I realize it is a little late, but here are some thoughts for the future:
Buy a cheap ($50) drone and learn to fly it. It is nothing like a Mavic, but it teaches you how to control a drone that has no automated control. That skill comes in handy if the automation failed on the Mavic.
Be sure you have lots of space. I know it is tempting to take off in your 10x10 living room with a couch, entertainment center and favorite chair, but that leaves about 3x4 to maneuver, and that isn't much. If weather is an issue, take the car out of the garage and use it... at least you'll have a little room.
As soon as you take off, put it in TRIPOD mode. That slows the controls and helps prevent "panic" movements.
Finally, ALWAYS take off with you and your drone looking in the same direction... not at each other. That way any movement you make will be "correct" and not have to be "reversed" because the directions are backward.
GET NEW PROPS! That nick will make it vibrate and could also crack and drop your Mavic out of the sky. Props are cheap insurance, so replace them if they become damaged.
Best of luck and take it slow... read the book twice and be twice as careful as you think you should. You'll get the hang of it and enjoy the hell out of it.
Gary |
