probonic
Flight distance : 61211 ft
PorkChop272 Posted at 2017-1-5 12:58
So after all this nothing is working with any consistency. yesterday everything worked in DJI GO except video, so I did a IMU calibration. Still no video image.Then Litchi started working video everything. Everything seemed good to go I don't trust it. Today nothing again.
Holding the icon on the connect page upper right gets me to a page that says . Equipment Default, Firmware Version : Loading , Downgrade firmware to ____________ , No availble firmware for downgrade.
If you run both Litchi and DJI Go on the same device, you may need to "Force Stop" the one you are not using.
I have found this myself running Litchi and DJI Go on my Galaxy S7.
First make sure the one you are not using is not running as a background task by using the tasks button (bottom left). Then go into Applications in settings (you may also need to go into Application manager depending on the device), choose Litchi or DJI GO (whichever you are *not* using), and choose "Force Stop".
This has solved similar problems for me in the past. Basically the two apps fight with each other for control. Even if it appears the other isn't running, it can be running in the background.
