Henry M.Y.
Flight distance : 11548839 ft
Dan UK Posted at 2017-1-4 04:15
Fantastic advice thankyou. So refreshing to have real world advice.
I can get a Phantom 4 Pro all you need kit which comes with 2 batteries then get another 5 which would make 7 in total so about 2 and a half - 3 hours in the air (enough time for the first ones used to recharge and so on) spare props charging hub, HDMI output module etc. for about $2540 from DJI direct.
Same sort of thing for the Phantom 3 pro would be $1324 a lot less!
Hi Dan,
I started off in late 2015 with the Inspire 1 Pro when it was first released and had since then enjoyed the ability to adopt lenses with different focal lengths. Before that, I didn't have any experience in drone flying or RC helicopter flying. Comparing with my little experience in RC aerobatic planes, piloting and filming with the Inspire 1 Pro is super easy. The 15 minutes flight time per battery has never been a problem to me. It was the weight of the full set of equipment (aircraft, lenses, batteries & etc.) that limited my usage of it in aerial photography and filming, e.g. when go hiking in the mountains.
I later expanded my fleet with a Phantom 3 Pro and a Mavic Pro, serving different needs, e.g. air-borne longevity, or portability. However, when I go out and seek for absolute control on framing perspective, on changing to specific shutter speed on the fly, or when under extreme weather conditions (e.g. high wind, low light), nothing except the Inspire 1 RAW and the Inspire 2 with X5s can beat the Inspire 1 Pro.
On the other end, if the filming will be inside a venue, I would definitely go with my Mavic Pro for its lock-on hovering accuracy and minimal disturbance (noise, propelling gust, and phycological stress) to the people inside the venue.
Hope my 2 cents can give you a reference in analysing your needs. Only you can figure out what you need. As long as you choose according to your needs, whatever you've chosen from DJI will not let you down. Its products had proven to me their functionality, precision, and reliability.
Henry
