Hi friends, i want share this with you
....in this video you cans see what happened, but before, check the pictures.
first picture: this was my litchi flightplan
second picture: here from google hearts you can see the terrain go up more than 10 meters, my point was 10 mt
MerlinL14 Posted at 2017-1-5 02:51
One of the limitations of the Standard. I take it you knew this was going to happen!
If you create your flight plan with google maps and import to Litchi mission hub you can setup to fly relative to ground elevation preventing this type of crash. Check out the youtube video How to program Litchi app to fly relative to ground.
You know when planning a waypoint mission, even when using Litchi by itself the relative ground elevation is there to see if you look at the properties of each waypoint individual. Just under "Altitude".
