I have the Black Pearl 5.8 GHz 7 channel monitor. I have a Fatshark 250mW transmitter. The video quality is occasionally garbled looking no matter which channel I use. I am using the stock antennas. Would the video quality improve with better antennas?
At which range is your video quality poor, even at very close range? With a 250mW transmitter and whip antennas you should get up to 500m of good video feed. Other antennas like the SpiroNet would generally give you more range.
Did you perhaps start up your phantom without having an antenna on your transmitter? This could blow the tranmitter and would also cause the very poor range/signal strength.
Remember that the signal strength from whip antennas comes off from the sides, not from the tip of the antenna. So if it is over you, don't point the antenna vertically up, keep it horizontal.
