fansc64b8b9e
Welllll.......wanted to come back on here and THANK everyone for your inputs, and ideas. I was finally able to plug in the Inspire2 to my computer, and I ran the latest copy of the DJI ASSISTANT software, and then I did the factory reset, and a firmware upgrade. I am not that "computer savvy" but I pulled it off, and then, with fingers crossed, I took the think outside. At first the Inspire 2 would not connect to my controller, but then I remembered the little "switch" which you have to move when you connect it to the DJI ASSISTANT software. (It tells you to move the switch when you select the "how to connect" help button. So, I powered everything down, moved the little switch back "up" and then I powered everything back up, and everything linked. I did nothing else, but after I got a good GPS lock, I took it off and flew it around, taking some still images and also some video shorts. The time of day was dusk, and I expected to come back inside and see the same red dots, but they are GONE! GONE! The images are now crystal clear, and in fact incredibly so. It's just AMAZING! And to add to my joy now the video files no longer have lines jumping through them and there are no longer the strings of colored dots dancing across the videos either. Sooooo, I've gone from a disappointed customer to a very happy one! And, I don't have to mail anything back!!! Hopefully, this will help others as well!
Again, thanks to those of you who read my issue and responded to it. And a special thanks to the unknown DJI guy who helped me on the customer support line. This issue is resolved for me! |
