What model do you have? What firmware do you have on the RC right Now. If it is 1.5 then the RC does not need updating. The RC on the Phantom advance and Pro and Inspires is updated through the Go App and a wi Fi signal.
Reply to MY post if you need Help,
-donnie
tips
TIPS - After 1.3 the update FOR the Transmitter is NOT through the SD Card it is through The DJI go app and WI-FI connection. -Always update the aircraft first-
-Make sure you download the proper firmware. If you have the Pro make sure not downloading for the Advanced or standard.
-Make sure you only download the Bin File to the FRESH FORMATTED SD CARD.
-Make sure transmitter is NOT on when downloading Firmware to aircraft ( VERY IMPORTANT)
-When installing SD with fresh firmware card in Aircraft make sure it is off. Then turn on aircraft, the firmware will then load.
-YOU CANT JUMP FROM 1.4 TO 1.6. You must stair step 1.3 to 1.4 to 1.5 to 1.6
-All the firmware numbers for the RC - aircraft- Go App - Camera WONT BE THE SAME . For example the current aircraft firmware is 1.6.0.40 but the RC Firmware is 1.5.70. A LOT OF FOLKS GET CONFUSED ON THIS (Including Yours Truly when first starting out.)
-Sometimes only the aircraft gets an update and not RC Transmitter Read the pdf on the downloads page so you know what’s going on for example 1.6.0.40 is only for the aircraft and batteries.
-Make sure to read what each update is effecting. For example 1.6.0.4.0 will require each battery to be updated as well. Keep Informed.
-Macs sometimes dont format SD cards well. When Formatting is in doubt FORMAT ON THE AIRCRAFT, go to camera settings on dji go app , open the tool icon , on bottom is Format SD card option
-Updates sometimes take a while, wait for the tone to change to d-dd d-dd d-dd d-dd d-dd d-dd d-dd or the green light even better.
-If you hear a long dddddddddddddddddddddddddddddddddddddddddddddd it has failed.
-updating is not an option for just the aircraft, IF there is also an update at that time for the Transmitter you MUST do it. -Updates for the Phantom Standard are Only Done through GO-App and Wi-Fi, no SD Firmware to upload. - You cant Rollback the Battery Firmware once installed. -When doing a Rollback, confirm the Current firmware on the Aircraft and then Rollback Firmware in Order. NO JUMPING ALLOWED
