Dobmatt
Flight distance : 1831050 ft
Donnie Stugots Posted at 2017-1-7 05:38
I find that gimbal Pitch EXP to be way to sensitive , I have mine like at 5 but anything above that is ways to fast , it is like the graph for the expo is a lopsided bell if you know what I mean . This is on my Inspire Pro , andI am still trying to get the settings just right.
donnie
I agree, but that's not the issue here, Donnie. Gimbal Pitch EXP parameter is usable and manageable to a degree, still the moment you let the dial wheel go to neutral center position, it stops the pitch abruptly.
I'm talking about Gimbal Pitch Smoothness parameter (line 4 on Advanced Settings page). This value - when tweaked on Phantom 3 Pro - controls the "fade" in and out when executing gimbal pitch. Another words pitch command triggers linear ramp up, starting from zero to whatever value is set at EXP. After the command is canceled, the gimbal continue to pitch slowing to zero. Really nice feature for slow, peaceful landscape filming.
For some reason this feature is not active with my Inspire 1 Pro.
Cheers, Brother. |
