Donnie Stugots
Flight distance : 3636782 ft
I would change those locks ASAP, I replace mine every 3 monts or so , and it is inexpensive insurance . My concern is that the electric motor may be overheating and causing it to get warped and therefore causing the challenge. do you happen to have a point and shot temp gauge? they are fairly inexpensive and a valuable tool to keep in the kit , you could then compare temps of each mortor . If not at least do a touch comparison to see if the suspect prop locks are getting overheated .
I hope this helps , and order the new locks ASAP, I would also get another set of props as well.
let me know what you find out .
****Also did you recently replace the props or anything like that ? I would really look close to see wht is causing the problem , maybe you can spot it in comparison with the others, only the white ones you say? Interesting . Also is this outside when happening , or in all climate conditions , weather could play a factor as well.
donnie
