BillW50
DronesBeCrazy Posted at 2017-1-15 11:13
Very new to this and just joined the forum today. My experience is similar, though I don't dare even try to fly my P3S. I received it late December while I was on vacation. I unboxed it and checked parts when I got home on Jan 2. The smart battery is very difficult to remove from the unit but other than that it seemed all the parts were there. Last week I charged the battery and the controller and I have watched all the tutorials several times. Today, My daughter and I tried to set it up and were planning to fly. First off the App doesn't work at all on my Samsun S5. Works on my daughters Iphone or sems to. first thing the app said to do was update the firmware. This failed and now the drone makes loud beeping noises when turned on and it doesn't stop until you turn it off. It seems effectively dead. The camera gimbal seems oddly shaky and in fact the gimbal lock doesn't actually hold the gimbal in place as it does not lock. I am now hesitant to move forward scared to damage the equipment but I also feelthat I suddenly have a $360 brick.
Well I would try updating it again. Just follow the instructions below.
How To Perform A Firmware Upgrade
by Microcyb
2016-12-29 7AM CST
For others here are the steps to insure you get a good firmware update to your P3S.
1. insure all other apps are closed on your mobile phone.
2. Make sure you have both the controller and the intelligent battery charged,
3. Plug in your intelligent battery into your Phantom 3 Standard (don't turn on yet).
4. Install the DJI Go app on your mobile device.
5. Turn on your controller and turn your controller upside down. You will see a small tag that shows you the controllers wireless SSID and password.
6. Go to your wireless setting on your phone and select the Phantom 3 (per step 5).
7. Start up the DJI Go app.
8. Plug in and turn on (tap tap hold) your PS3 intelligent battery.
9. Wait for the firmware update notice on the DJI Go app. If you do not have cell, it will ask to switch back to your home wireless Internet for download. [Once done, connect WiFi back to DJI]
10. After the download, it will ask if you want to start the firmware update. Do this and just walk away.
You will hear beeping, hiss sounds, and other odd stuff but do not touch anything.
This can take 30 minutes or so.
If the firmware update fails, simply exit the DJI Go app, turn off the PS3 and turn it back on, then start up the DJI Go app again.
