Helimage
Flight distance : 144140 ft
Finland
You have more bitrate to play with if you shoot in 4K, but if the final output is going to be in 1080p or your PC can't handle 4K footage, you might wanna consider shooting in 1080p. Technically lower frame rates grant each frame more data, so unless you're going for slow motion, keep shooting in 24-30fps.
Jerkiness is usually the result of fast shutter speeds, so try to aim for 1/60 with 30fps and 1/120 with 60fps. Since P3P has a fixed aperture, you probably need ND filters to achieve proper shutter speeds. |
