BuzzCut
PolarPro Posted at 2017-1-19 10:47
Our engineering actually puts less stress on the Mavic, it widens the stance and disperses the weight of the drone over a greater surface area, actually reducing the amount of stress on the back of the done. In addition to the better weight/impact distribution it provides a wider stance which makes it more stable.
-Jeff from PolarPro
Thanks, Jeff.
I agree with the stability perspective. I still prefer the idea of the rear load taking place on/around the aluminum heat sink plate vs. the legs.
I've seen from some of the initial crashes that that hinge/plate is vulnerable since it's a foldable. More so because the rear legs fold under vs folding in. In a front/side crash the front legs almost have built-in shock absorption from the hinging, whereas the rears do not. I had a SNAFU where my Mavic skated low across my patio (broken prop) and the rear legs would have come more into play if they had leg extensions attached.
I have no crash data to back that up, but I really don't want to collect that crash data So, I'll have to go with my gut.
If you guys release a design that works off of the rear center support I'll be a buyer for sure. You guys make quality products. |
