DarrenE
fansc1fa131d Posted at 2017-1-21 10:28
Thanks Darren. Don't why I am down as a beginner as I have been flying since last May and have a PFCO. One moment of inattention however!
I have replaced the plate and camera. Everything seems ok but I haven't tried a flight as I can't get it into travel mode. Otherwise the undercarriage rises and lowers as it should. I've tried a firmware update. Any ideas?
It's all it takes! - that or sheer bad luck!!
Re: the forum ranking thing - just ignore it. It's purely based on the number of postings a member's made in the forums
That's great to hear you're back in business. Strange about the travel mode though.. Some common causes are the surface the craft is on - sounds silly but is it sitting somewhere it's transitioned okay in the past? It might be worth trying it on a few, low-friction surfaces.
Also if you're trying it in the app, perhaps give the controller a try.
If all else fails, you could try setting it manually using a small screwdriver on the bottom of the jackscrew, with the craft powered off. That'd at least mean you could transport it to try a flight, even if the travel mode issue remains. It'd also force the craft to come out of travel mode the first time you power it back on. That might be all it takes to un-screw the transportation-position logic..
Let us know how you get on! |
