Hello Everyone Just received my new P4P and really like it, good build quality and looks very professional, for my new business I'm starting. However I need some help which might involve sending it back. So I went through all the youtube channels and instructions to set my P4P up, firmware all done successfully etc etc. (Check)
However being I have a very keen and precise eye, I have noticed that my camera is pointing slightly to the right once its initialized. I performed a Gimbal calibration and even calibrated it on the screen however it does point to the right and is not centred. When I performed the Gimbal Calibration it did go through the full left and full right initialization but still my camera is not centred as it should be. I'm hoping this can be fixed with some form of Gimbal firmware update, a fellow P3PA user has said it shouldn’t matter too much but it raise some concern. I did raise a call with DJI but no one has yet responded. Attached is a picture: It shows my drone on a bit of paper which is parallel to laminate flooring and that’s dead straight and the drone is straight however the ruler clear shows the Gimbal is pointing to the right (or left if you look from above) Any ideas from anyone would be appreciated. Thanks Regards |
