drb1215
A lot of it depends on the platform you have to run it on, what your budget is, and how much time do you want to spend learning how to use it.
For some of the upper end packages like Final Cut Pro X and Premier Pro CC they offer a free 30 day trial. A suggestion would be to get a free trial and then check out YouTube for tutorials. This way you can play with different packages and see what you are most comfortable with.
I personally run Final Cut Pro X. I started with iMovie, so the transition was fairly easy. |
