fans54d6094f
Flight distance : 4219 ft
MavicUser Posted at 2017-1-20 17:56
Sounds like a bad compass calibration. Why did you calibrate? Did the app ask you to do that when you started the Mavic up on the floor of the balcony? The key to compass calibration is to NEVER calibrate if you are surrounded by metal/magnetic interference, which is what you would be doing if you calibrated on your balcony.
If you start up your Mavic in a magnetically noisy environment, e.g. the roof/balcony of a tall building, DO NOT CALIBRATE even if the app tells you to... All that metal around you in the building is screwing around with the compasses in the Mavic, and if you calibrate there, you will be in big trouble once the Mavic has flown away from the building, because once the Mavic is not surrounded by all that metal, the compass calibration will be off, and cause the Mavic not only to have a bad compass, but could possible loose GPS as well due to this..
Thank you. That is probably the cause. The balcony has little metal (wood railings, etc.) but there is wiring in the walls and, now that I think about it, a metal roof! I really screwed up. |
