RicardoGray
Flight distance : 4356421 ft
mark@targetingp Posted at 2017-1-22 06:54
Thanks Raptor Heli. Unfortunately I can't get past the drone beeping within seconds after I turn it on. I have tried removing SD, switching Batteries, and yes, I did read and erase all update log info. The place I'm at now is needing to get past the "Beep, Beep, Beep"!
The process can take up to 15-20 minutes sometime. Make sure you have the "bin" only on the sd-card, put it in the drone, and turn it on. Light on camera should flash between red & green as it updates. Remember the RC must not be turned on, only the Phantom. Because it didn't complete the original upgrade, I'm not sure what else to say. I think it should restart, but someone else might be able to offer up how to reset things. hang in there!
If you do get it to complete you should here the D-DD,D-DD sound, and light will be green on the camera. You may have to re-link the RC too.
