Gallacherboy
Flight distance : 778209 ft
Step 2: Connect the controller to PC, run DJI Assist and Refresh the Firmware, once complete, disconnect only when prompted to do so. If you look under the Firmware tab, you will see the version of which firmware your controller is, it will be highlighted in RED as CURRENT, you should have a Reinstall or Refresh tab, if not, I will check on DJI Assist and come back to you. First time I did Refresh the firmware with out finding the Refresh tab. Unless its changed |
