Dave P
Flight distance : 207664 ft
So, I said I would report back after removing 3.1.2 and installing 3.1.1, and it now allows me to implement Follow Me mode with no Aircraft Too Far Away message, so it seems to be fairly conclusive that there is a bug in 3.1.2. That said I wasn't impress with the 2 test flights of Follow Me - the first one it moved from side to side and as soon as I took a step moved about 10m then back again and there were a few trees nearby so I cancelled it. The second was in a big open field and when I started walking it did nothing for a second or so them lurched forward and overtook me, then went backwards again, off to the side, back around me etc. I had 14/14 satellites locked, good satellite, WiFi strength etc. That said my device is not supported but I have a Nexus 7 II on the way so let's see what that does. |
