RicardoGray
Flight distance : 4356421 ft
Depending on how old your Phantom, is, there might be a bug-fix you could take advantage of. But, for the most part if the bird flies ok and it does what you want, leave it alone. You will be reminded that a "Firmware Upgrade" is available, but you can ignore that if you chose. There are many discussions about this subject. I for one, like to always be up to date at least with the firmware. I have tried to do the same with the app, but I have reverted back to 2.9.1 because I didn't like the maps, and a couple other things that changed. But I do have the latest firmware. It is your choice. Many are just like you, and choose to leave it alone. There is nothing wrong with that either. |
