Kankles
Flight distance : 3963865 ft
This may help if you have tried everything else. At the very least it can't hurt.
1. Make sure all of your firmware is up to date. If updated, restart your drone or follow prompts.
2. Check your details on your IMU. If they look off (and maybe just to be sure) calibrate your IMU by following the easy prompts. Always make sure you are away from metal/interference causing objects. After Calibration, restart your drone or follow prompts.
3. Calibrate your compass. Follow Prompts
4. Recalibrate your gimbal
After taking these steps and still no luck (unless you know how to check your wiring/gimbal attachments), you should send it in. This doesn't seem like a firmware issue at all. However if you think it may be try downgrading your current firmware and then restarting your drone to see if that fixes the issue. Unlikely, but you never know. Good luck man |
