I've scoured the boards and haven't been able to find an answer...
On a few occasions I found myself wanting to look skyward rather than forward or down. Is it possible to increase the camera tilt beyond the 90-degree (level) upwards to 100-degree or so?
The H3-3D can do it. My P2V+ v3 shows up as a Phantom2 in the assistant program when the H3-3D gimbal is on it. The assitant softwate has a gimbal limit menu that allows you to set the gimbal above 90 degrees. Unfortunately that menu does show under the standard P2V+.
my rotorpixel goes above horizon level on my vision non-plus. but my stock vision non-plus camera would not go above.
edit: sorry, i see your post title said v+, apologies for the errant post
