hallmark007
Flight distance : 9827923 ft
Jackson01 Posted at 2017-1-30 23:42
The props never came off and they dont have a mark on them. It was a all really quite gentle.
The motors spin fine if the props are off and it will go as normal its only when i put the props on it does this now
You obviously have a problem with your motors, I suspect caused by what happened, the motors are driven by ESC chips which are controlled by IMU , if wires have become dislodged because of your accident then they may need to be checked, but first I would check movement in the motors simple just checking them against the ones that are working ok, just simply turning them by hand.
You may have some grit or grass trapped inside the motors, if you are inclined to check this by stripping down the motors you can, if not I would just send it in for repair.
You don't want to take to the sky with dodgy motors until they are thoroughly checked.
Good luck.. |
