Three of the motors make this horrible crunching sound when I turn them by hand. But it doesn't seem to affect flight. But, I'm concern over the longeveity of the unit.
I do have the Refresh Service. So, Should I send it in or I'm just paranoid.
Opinions and thoughts much appreciated
Before doing that hold the Mavic upside down and turn the motors back and forth, if you can blow a little compressed air in the top of the motor while its upside down and you are turning it. You really should not fly with the motors in this state.
You don't lube a contamination problem… Do you have sand between the rotor and stator… Either use an air compressor or get a can of compressed air to clean it out. I haven't done it yet but the motor should also disassemble fairly easily, giving you the ability to separate the rotor from the stater giving it a good wipe down with some rubbing alcohol or other mild cleaner. chances are they will do the same and charge you the $79 fee for refresh… Clean it fly it till the pukes then send it in.
