DroneFlying
Flight distance : 10774613 ft
Question: Is it safe to take off safe? Or should I move before take off?
This is the message that reads something like, "Compass error; move aircraft or recalibrate compass", correct? If so, I'd strongly recommend that you do try to find another spot where you don't get that message and that you don't recalibrate your compass there, at least assuming that it previously was properly calibrated.
Regarding the rest, this is mostly conjecture on my part, but I'd think you probably couldn't cause the kind of magnetic interference that would result in a crash. I'd be a little more likely to believe that your controller might have interfered with his, but again that's strictly guesswork. In any case, from what you described it doesn't sound to me like you did anything wrong. I always hate to see someone's hard-earned property damaged or destroyed, but sometimes it just happens. As far as the Mavic instruction manual goes, this is the only thing I can recall that's somewhat relevant:
"To prevent transmission interference, do not operate more than three aircrafts [sic] in the same area." |
