DroneFlying
Flight distance : 10774613 ft
In what conditions are you flying and how are you flying? Lots of sport mode and / or hovering in high winds, for example?
Flight time depends very much on how you fly and in what conditions. In what I'd call a "normal" flight -- light to moderate winds, no sport mode, etc. -- I consistently get 20 or more minutes of flight time out of all my batteries, and 22 minutes seems pretty typical. I've gotten up to 24 minutes and still landed with a reasonable amount of reserve, so DJI's specs seem pretty accurate to me.
I've read a couple of times that with brand new LiPo batteries it's best to only drain them down to 50% for the first handful (10 is sometimes thrown out) of uses. I don't know if there's any truth to that, but there doesn't seem to be any harm in it, so I've tended to follow that rule of thumb.
I'm assuming that you're referring to the 10% threshold that's supposed to "reset" the battery. You definitely don't need to / shouldn't try to do that on a routine basis, especially since at 10% (or higher, depending on your settings) you'll get a critically low battery warning, at which point the aircraft will insist on landing. If your batteries are new then you shouldn't need to do this to get the expected performance out of them; at least I never did. |
