DJI Mavic Pro - Connecting a Mobile Device
123Next >
115810 87 2017-2-8
DJI Support
Flight distance : 2408 ft
Here's how to connect a mobile device to your Mavic Pro remote controller.
2017-2-8
shoxer
Flight distance : 2621 ft
mhm, awesome...
few topics, many questions and no answer.
osmo+ via dji go and mavic via dji go4. how to make them work on android phone?
if go app is instaled can't connect to mavic. if go4 is installed can't connect to osmo+ .
Force stop is not helping.
Y U no add Osmo/+/Mobile in DJI GO4 app if there is this problem?
AND
Mavic is no longer supported with DJI GO so there is no other way then uninstalling an app i don't want to use at the moment.
2017-2-8
Jenee 2
Flight distance : 7852129 ft
It's a good video and worthwhile watching as many people have been caught out by not removing the cable from the side when using the USB port at the bottom.
2017-2-8
Capt Hurls
Flight distance : 84675 ft
Jenee 2 Posted at 2017-2-8 23:41
Yes - that one got me first time I tried!
2017-2-10
Airwolf13
Flight distance : 36995 ft
So  now that I've hooked it up correctly why does it only record my still shots to phone but not my video!
2017-2-10
fansc2c90ed0
I recently received my Mavic Pro, been watching the DJI tutorials as well as other YouTube how to videos to educate myself.
In these videos, it says to stay away from metal objects during calibration. My issue is that I have a metal hip and I have some metal screws in my spine. Is this going to be an issue during calibration?
I guess when it is saying stay away from metal objects, are there more specifics regarding this? There is metal on a persons belt, jacket, watch etc...
Thank you.
2017-2-11
Airwolf13
Fences, tables, etc., LARGE chunks of steel...you should be fine
2017-2-11
Lonewolf5
Flight distance : 3402 ft
I still can't connect my phone to the controller and because of that I can't activate my drone and I've been trying for 3 weeks now. I emailed DJI and have not receive a response back, and I called them and they told me what to do and I already had tried all the methods they gave me and still nothing. Please help.
2017-2-11
dronist
Lonewolf5 Posted at 2017-2-11 21:11
This is for IOS IPHONE6S+, Force close all of the apps even GO4 APP.
* Turn RC, show connected, turn on the AC, RC should say connected to AC, plug your phone, open GO 4 APP, wait few seconds and you should have the GO FLY NOW TURN BLUE.
If did not work, turn off AC, then RC, exit the GO4 APP and repeat in the same order.
sometimes it works in the first time and sometimes I have to do it 2 or 3 times before I connect.
Good luck...
2017-2-12
Ex Machina
Flight distance : 1806362 ft
fansc2c90ed0 Posted at 2017-2-11 14:28
I have four titanium skull plates and was worried about the same thing, turns out not to be a problem at all.
DJI-Ken does say to leave your keys behind, so when I'm prompted to calibrate the compass, I set the Mavic down where I plan to launch, walk a few yards away and set down my controller and keychain, or any other metal I might have, start calibration, and walk back to the drone to complete the calibration steps. I don't bother taking off my watch and have a belt with lots of metal rivets that doesn't seem to be a problem, either.
2017-2-12
Ex Machina
What phone are you using, we'll need more info in order to help. If you've tried all the steps DJI suggested, it might be time to send it in to the service center for evaluation. Before doing that, though, I'd try to see if another DJI-approved phone works for you -- it might just be your phone that's acting up rather than the Mavic.
2017-2-12
Lonewolf5
Ex Machina Posted at 2017-2-12 20:46
I've tried an iPhone 5, and iPhone 6, and an iPhones 7plus and none of them have worked.
2017-2-13
Ex Machina
Lonewolf5 Posted at 2017-2-13 08:06
Have you tried replacing the connecting cable with one of your Lightening cables in the bottom port? I think you have to unplug the side port cable first. If that doesn't work, I'd expect the problem to be in the RC itself, which would need to be sent in for service/replacement.
If your phones can connect with the RC, but the RC can't connect to the Mavic, then the RC and Mavic may not be linked; instructions for doing so are in the Mavic manual v1.2 on pg 39.
2017-2-13
Lonewolf5
Ex Machina Posted at 2017-2-13 08:21
I have tried a different cable and my phone shows it's charging when I connect it but it doesn't let me connect it to the drone or RC so I'm not sure what it could be. I may try to see if maybe the rc isn't connected to the mavic but I doubt that would be it but it's worth a shot.
2017-2-13
WYHSniper1007
Flight distance : 1003822 ft
When will the new firmware of mavic release?
2017-2-16
fans8c7e7e0a
Samsung Galaxy ON5 works perfect so far !
2017-2-17
dronist
WYHSniper1007 Posted at 2017-2-16 12:55
Already been released on Feb 14
2017-2-17
eduardoCosta14
Brazil
Try to replace the cable, use the USB connector under the remote control.
2017-2-18
eduardoCosta14
Brazil
2017-2-18
SR-71Habu
Flight distance : 191125 ft
Dude, your post is tugging at the heartstrings...
I ain't DJI, and I won't call myself a Mavic expert yet, but let me just offer this advice to do as a general step to answer a few different questions.
Borrow another phone or device, install DJI Go4, login to your DJI account inside Go and then go ahead and register the drone, and then update or even fly too if you want. At least you have your drone reg'ed, and you know that your phone is definitively the issue.
2017-2-18
SR-71Habu
Ex Machina Posted at 2017-2-12 20:41
Prolly being a bit nitpicky here Ex, but I can't tell if Ken clarified the issue with your plates (must be a story there...). He said it isn't a problem at all because your plates are titanium which is non-ferrous, not because metal in the body might not ever be a problem.
In fact his paranoia (perhaps justified) about a keychain would be a concern since the human body is not very effective shielding for magnetic fields. Depending on the mass and location of the devices in the body I would guesstimate that a relatively small chunk of metal like a key chain that needs to be 4-5 ft or more away from the sensors would be *less* magnetically attractive than chunks of ferrous metal in the body.
There is not any type of body tissue/bone that shields the effects of electro magnetism very much and it seems from what I read around here that these sensors are perceived as super finicky (beyond what I believe to be true, FWIW), so I'd say to the OP to exercise caution after a calibration and note anything quirky. Or just find a volunteer to compass dance for 30 secs.
2017-2-18
chalde
Flight distance : 668314 ft
Lonewolf5 Posted at 2017-2-13 11:04
I have the same issue, using a Samsung Galaxy S7 Edge. If I plug the phone using the side plug, with the original cable, the phone will show as "charging" when the controller is powered on, but DJI 4 go or Litchi will not start and the Mavic itself will show as disconnected (on the phone, in the App).
If I use the bottom plug, it works perfectly.
It used to work on my first few flights, but then, lost connection while flying and since then, no luck getting it to work. Wondering if it's my cable that is defective. Ordering another Male to Male Micro USB to test. Hopefully, it's just the cable, and not the controller. Charging via the port is fine too.
Or it could be the S7 needing too much power and the side port is not working well with those.
2017-2-19
Midwest_Blue
Flight distance : 202247 ft
chalde Posted at 2017-2-19 11:12
I also Have the 7 edge. I tried to change the phone setting, to not charging. But don't take affect . I feel the controller has a shorting battery life, cause it's charging the phone. I do try to have everything a full 100% charged. A little frustrated . But, Hey! .If that really the only problem I have. Using Litchi as the default program for the MP. I have tried both controller ports, too.
2017-2-20
David000
I'm having a slightly different issue... the DJI GO 4 app is crashing on both my Galaxy S7 edge and Galaxy S5 phones.  It seems to have started after the firmware upgrade a few days ago.  I don't understand how upgrading the firmware on the Mavic creates an issue with the app... but that's the only factor in my flight environment that has changed.
2017-2-20
PR MAVIC
Is it just me or are other users experiencing problems using a iPhone5 with the DJI go app. It intermittently connects with the 5 but the others 6s connects every time without fail. Any help would be much appreciated.
Mavic pro user.
2017-2-20
chalde
Midwest_Blue Posted at 2017-2-20 09:09
Are you able to connect Litchi with your S7, with side port?
I also tried with a Galaxy Note 3 - same issue, using the side port. Got a replacement cable ordered. Hopefully, it's just the cable.
I don't mind using the bottom port, but it's less "elegant".
2017-2-20
fans9d21242f
Singapore
I have the same issue too, using a Samsung Galaxy S7 Edge. If I plug the phone using the side plug and the bottom usb, with the original cable, the phone will show as "charging" when the controller is powered on , it drain off my rc power fast ...But the app works perfectly ! whats going wrong ? the RC ,phone or the cable itself....?
2017-2-20
chalde
fans9d21242f Posted at 2017-2-20 21:40
App is not connecting for me if I use the side USB on the RC, to connect to the phone.
It only works if I use the bottom USB connection on the RC to connect to my phone.
Battery on either doesn't seem affected that way tho.
2017-2-21
David000
David000 Posted at 2017-2-20 10:51
I resolved the app crashes.  Here is how (for Android devices):
Open your file explorer on your device and navigate to your home file directory.  This is either referred to as "Device Storage" or /storage/emulated/0.
You will be deleting the DJI and the dji.go.v4 folders, so if you need your cached flight logs or cached media, backup the DJI folder.  Proceed to delete the DJI and dji.go.v4 folders, then try launching the app.
Hopefully this works for you. It did for me on my Galaxy S7 Edge!
2017-2-21
chalde
Received my replacement cable and it's been connecting fine using the side USB port. I'll be extra careful with the new cable not to pinch it excessively or bend it too much. Probably not going to use the clamp either so I have more movement freedom with the cable.
So, if you have problem with the side connector, if possible, try a different cable ($8 (+$10 shipping) on DJI for the replacement, roughly same on Amazon, minus shipping cost if you're prime customer. Type C to Type C).
2017-2-23
JohnnieYaz
Flight distance : 5137874 ft
I personally take the sliding hollow plastic block out from the left handle and keep my phone in my case.  I can see it to plug it in, and works for me.
2017-2-23
Citation
Flight distance : 134908 ft
Love the video, please put out one for every operation on the controller.
2017-2-23
PassBy
Flight distance : 139967 ft
Malaysia
Nice and clear video clip.. thanks for teaching..
2017-2-23
Alex Hong
Flight distance : 68524 ft
New Zealand
very good
2017-2-25
Alex Hong
New Zealand
Thanks, I connected my Samsung Galaxy note 3 but still I can't connect with my Ipad air A1567 on USB on Controller
2017-2-25
Fireside
Flight distance : 56325 ft
I'm new to forums and even sure how to navigate in them. Really could use some guidance on downloaded and editing videos. Tx
2017-2-25
Fireside
Citation Posted at 2017-2-23 14:11
I'm new to video editing and don't even know how to download them to my pc. Followed directions without any luck. Suggestion please?
2017-2-25
MRK
India
HI,
I am Moses from india, I have recently purchased Mavic pro Combo pack. I am using it for a while now and i having a issue while connecting my mobile through the Remote Controller.
As per the videos and support says, when we connect the mobile device on to the controller the mobile should get charging simuntaniously right???? but when i connect the mobile that particular time it show like charging then when i start using the drone, the mobile is left uncharged??? can anyone helps me out how to resolve this issue? or anyone has facing the same like me!!!!
I am using Iphone6s as my mobile device.
2017-2-25
twh1968
What kind of phone are using , and are you using the Go 4 app ?
2017-2-28
chunky
Flight distance : 128514 ft
works fine with my pixel xl
2017-2-28
123Next >
