1. Tested Herbicides
Nong1Wang's 85% MCPA-Na water soluble powder, and (Shi-Er-Long) 200g/l Fluroxypyr Emulsifiable Concentrate.
2. Spraying Method
Using the DJI AGRAS MG-1, 6000ml liquids per acre, Smart Operation Mode, flying speed 5m/s, height 1.5m, spray rate LED3, spray width 4.5m.
Drone pilot spraying the herbicide
3. Aerial Spray Location and Area
The aerial spray experiment was conducted at Dayang Town, Qiaocheng District, Haozhou City, Anhui Province over an area of 4.94 acres.
4. Weeds Species
Annual broadleaf weeds such as cleavers, descurainia sophia and shepherd's purse, etc.
5. Spraying Time and Temperature
As spring weeds are normally stronger and more herbicide-resistant, increasing the herbicide dosage increases the cost and hazards to wheat and reaped crops. As a result, this experiment was conducted in winter with the wheat at the early tillering stage. The specific time of the experiment was at 11:00am on November 19 2016.
As temperature may have a direct impact on the spraying effects of weed killers, especially systemic conduction herbicides, it is critical to spray at the appropriate temperature. The experiment was conducted on a 15℃ cloudy day with a gentle breeze.
6. Operation Scenes
Fill the spray tank with herbicide mix
A group photo shot after the spraying
Survey
20 days after the drone spraying, the experimenters returned to the site to observe the effect of the spray weeding and compare the results with the non-sprayed fields as shown below:
Photo 1
Non-sprayed field Sprayed Field
