Brian Fist
Flight distance : 19928 ft
Hey guys, I don't have a nVidia Shield K1, but I am running custom "vanilla" ROMs on a Samsung Galaxy Tab Pro 8.4. Some of my findings seem to back what some of you guys are experiencing, so I figure I would add this as a "data point".
The Galaxy Tab Pro 8.4 is forever "stuck" on KitKat 4.4.2 because Samsung abandoned the tablet within 6 months of releasing it. DJI GO 4 also has major issues running on this stock OS on this tablet as well (app crashed errors, video streaming breaking up, unable to do firmware updates, etc), but since the tablet is more than powerful enough hardware wise I have been on a quest to find a newer OS version that will run DJO GO 4 stable and reliably.
I started out with 6.0.1 Marshmallow. On two different ROM builds (both listed as "stable" builds of vanilla 6.0.1) the DJI GO 4 app would freeze on exiting the flight mode (either quitting out entirely or even trying to go back to the DJI main screen would result in a lock). I could almost live with that, but as it is Marshmallow has a serious bug in regards to battery recharging that I just could not live with as well, so I was onto the next OS.
Next up was 7.1.1 Nougat. This OS was actually a bit more responsive than 6.0.1 Marshmallow, it had no problems charging the battery properly, and it seemed to run DJI GO 4 without issue.
Well, that was until I was outside flying my P4P for more than 10 minutes and I started running into the same issue most of you guys on Nougat have seen, in that the DJI GO 4 app just exits back to the main tablet screen without warning. Sure it is quite fast going back into the app and reconnecting (even though I found only 2 or 3 out of 4 tries would give me the "GO FLY" button and connect correctly, as it would sometimes not want to reconnect without me unplugging and replugging the USB cable back in, and even once I had it not want to reconnect until I powered off the controller and powered it back on, in which case I was *REALLY HAPPY* to find the bird initiate a RTH after the controller was off on it's own).
So, back to looking at available OSes and I am now running 5.1.1 Lollipop. The apps seems stable in test, but I have to wait a day or two for the rain to end before I can give it a shot flying.
I haven't heard of many issues with people running DJI GO 4 under 5.1.1, so I am hopeful I have found a winner. If not I also have a vanilla version of KitKat 4.4.4 I can run as well.
Kinda sad that DJI has so many problems with DJI GO 4. I would hope they take the development serious and look for some talent to actually fix app stability issues like this, since it is far from a "new problem".
I mean I can understand having issues with 7.0 Nougat, since it is a brand new OS. But for devices running 6.0.1/5.1.1/4.4.4/4.4.2 and such, those are old, stable, fixed OSes that should have ZERO issues running DJI GO 4. |
