hallmark007
Flight distance : 9827923 ft
Sorry to hear of your crash.
First flying indoors is not an easy exercise and requires a certain amount of skill and set up.
First I would recommend if you are a new flyer you don't try flying indoors until you master outdoor flying.
To fly indoors you need to be in opti mode, if you have some gps your aircraft is likely to change from gps to Atti thus making it very difficult to control especially in small spaces, to fly in opti mode you need plenty of light a floor surface that has plenty of texture so VPS can recognise and keeps your aircraft stable.
You need to change your RTH setting to hover, or you risk the AIrcraft trying to reach its RTH height and crashing into the ceiling if you loose signal.
I'm assuming you are new to flying or at least the Mavic, if you read the Manual it clearly tells you to fly in open spaces.
If you do this for a while to hone your flying skills and get to know and understand how Your aircraft it won't be long before you can fly with caution indoors.
So keep reading the Manual, watch all the tutorials plenty on this forum and you tube, and most of all have fun and enjoy.
If you can put up your flight where you crashed then maybe someone here can tell you what exactly went wrong..
Good Luck |
