D.Walls
Flight distance : 4908 ft
Seamless Media Posted at 2017-3-5 23:17
Would really love to see a bump in bitrate across the board, I wonder if there is any real hardware limitation in the Mavic preventing 100-150 Mbps, or if they have the bitrate artificially limited to preserve their upmarket sales on phantom 4 pro / Inspire. At the very least 60Mbps should be available/used in all resolutions so we can make a choice to compromise resolution for less compression.
That's right, 60Mbps is a low bitrate for 4k if you are planning to do some color correction, but for 2.7k that bitrate is ok, but it's 45Mbps so we have the same problem again. And I have not tested it but I'm sure that 1080P 30fps is like 30Mbps or so. |
